Alternator Fan Bolt Size request (see pic)
Anyone know the size socket I would need to turn the alternator fan bolt? (see pic part# 22)
Unfortunately I don't have the correct size and would like to purchase just the size I need.
Thanks in advance,
Puma
Thanks in advance,
Puma
Jarhead
Do you have the stock toolkit? If so, you've got everything you need. The nut is a 24 metric and to get it off you'll need a triple-square spline tool. Both the wrench and the spline tool should be in your factory tool kit. Be very, very, very careful when removing the shims and pulley halves. If they've never been removed they can be pretty rusted on. I would suggest spraying them with liquid wrench and letting them sit over night before trying to remove them if you're having any trouble. But whatever you do, don't bend or damage them. If they get out of whack they will rub on each other while they're spinning at a few thousand RPM and can create some serious heat.
Brian
Brian
Brian
Brian
