964 Forum 1989-1994
Wings gas pedal extender
Old 08-06-2005, 12:13 PM
burgass
burgass's Avatar
Old 08-06-2005, 08:27 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Originally Posted by dfinnegan
One difference I found was that previous posts had suggested pulling the existing connecting rod from the back of the existing pedal by pulling the ball joint on the end of the connecting rod from the back of the pedal. I found that there was a lock nut at the other end where the ball joint rod connected to the throttle linkage. I simply loosened the lock nut and then turned the rod out from the throttle linkage. No need to remove the ball joint from the back of the pedal. It simply spun in place allowing me to unthread it.
Not all pedals have this nut (mine did not) so I had to pull the ball out of the back of my pedal.
Marc
Quick Reply: Wings gas pedal extender
