Jumping DME Relay...what pins?
Sorry I had to be a bit short in my last post.
Pin 3 is the battery feed to the relay.
Pin 5 is Ignition modules + ECU
Pin 7 is Fuel pump + ECU.
If you make up the std three 1/4 inch blades joined by some reasonable cable you can first join 3 & 7 .You should hear the pump go . Then hook in 5 as well.Try the key and see what happens.
Geoff
Geoff
