Missing Relays
Hi All
The following relays are missing in the fuse box in the luggage compartment. R32 - Emergency Flasher USA, R44 Catalytic Converter Monitor, R51 - Pump Brake Booster, R52 - Control Unit FWE. Can anyone explain what these relays are for and are they necessary?
Thanx in advance
90 C2
BJ
Thanx in advance
90 C2
BJ
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear BJ,
R32 not needed you are not in the USA.
R44 not needed you are not in Japan
R51 not needed because you do not have a brake booster pump.
R52 not needed because you do not have a tip.
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
