Protecting Shiny Rotor Hubs
While detailing my Speedster, I noticed that the zinc (?) paint covering my rotor hubs were discolored. With a little “Goo Gone” and a lot of elbow grease, I was able to remove the zinc coating to reveal very bright rotor hubs.
My question is; the zinc coating was there to prevent rusting up…. Is there any kind of clear coating I can use to prevent rust – but won’t yellow over time? As the disc and rotor hub appear to be one piece, I would imagine the hub would heat up under braking.
Any ideas the type of clear coat that would work?? <img src="confused.gif" border="0">
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Brad, if you remove the dull gray coating that the factory has on the hubs, when you wash your car and take it for a "spin dry"...you will certainly get rust goop all over your nice and clean wheels. <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Been there, done that...a million times.
I have seen several people paint their hubs, either gray, black, even purple!
Either way, high temp. paint should be used...try engine block orange if you want to be "different".
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
