964 Forum 1989-1994
A/C condenser fan problem
Old 07-17-2005 | 05:34 PM
TA911-64's Avatar
TA911-64
Default A/C condenser fan problem
Has anyone experienced this problem? Whenever I turn on the A/C the
condenser fan (at left front fender) goes on and off continually (roughly
3 seconds on...3 seconds off ) This pattern remains no matter what settings
I use at the dash ( as long as the A/C is engaged). I believe it continues as I'm
driving (it's hard to tell since I can't hear it)
Tom 1991 C2 1966 911 20 years ago
Old 07-17-2005 | 05:49 PM
Computamedic's Avatar
Computamedic
Tom,
I'd bet you have a blown fuse in the rear electric panel for the rear blower.
Make sure the fuse is a 30A.
The other possibility is that the ballast resistor on top of the condenser has corroded and failed.
Regards
Dave
Old 07-18-2005 | 08:07 PM
TA911-64's Avatar
TA911-64
Thanks Dave...I'll check both of those ideas.
Tom
Old 07-19-2005 | 07:59 PM
paulnott's Avatar
paulnott
Just fixed the same thing. The resistor had corroded mounted on top of the condensor. I got a new one from design911.co.uk for around 29 pounds as I recall. A bit fiddly to fit, but solved the problem. There is a diagnosis in Adrians book on jumping the relay connectors to verify if it's the resistor. I also found a link on this site referring to the diagnosis (you'd need to do a search however).
Hope this helps.
Cheers,
Paul
Old 07-19-2005 | 08:19 PM
TA911-64's Avatar
TA911-64
Thanks Paul
Tom
Old 07-20-2005 | 09:42 AM
Johnny G Pipe's Avatar
Johnny G Pipe
Uhh, I thought that the on/off cycling was a normal first stage, with it going on to constant running when the temp. increases..
Looks like I need a new resistor too..
Quick Reply: A/C condenser fan problem
