964 Forum 1989-1994
First intake disassembly - oil, dirt and flow restriction?
Old 09-28-2005, 08:33 AM
springer3
springer3's Avatar
Originally Posted by chancecasey
...From what I've heard and read, the intuition is about as accurate as a coin toss when it comes to intake tweaks.
Thank you for voice of wisdom. Porsche has brilliant engineers, and has refined the 911 engine for 40 years. From what I see, they spare no expense on the engines. Shade tree engineering has very little chance of improving performance or fuel economy without degrading something else far worse.
If you can find a modification the factory used for its racing program, that may be worth a try. Simply grinding away metal in the hope of improvement will very likely be counterproductive.
Old 09-28-2005, 08:37 AM
DaveK
DaveK's Avatar
Would help your power to weight ratio though.
Old 09-28-2005, 09:16 AM
springer3
springer3's Avatar
Only if it did not reduce power.
Quick Reply: First intake disassembly - oil, dirt and flow restriction?
