View Poll Results: What would you do (or have done)
G-Pipe & exhaust
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
![](https://rennlist.com/forums/clear.gif)
0
0%
Voters: 86. You may not vote on this poll
Best exhaust modification on 964
Hey Tom, thanks for the more accurate trip estimate... 6 hours is not too bad... I wasn't planning on it but it would sure be fun to play there with you. I have not driven Laguna Seca in my C4 yet... been a while since I was there in my 65, about 7 years! Do you run Orange group? And a cat bypass and secondary bypass and cup airbox keep you quiet enough?
Garrett: I've not yet run with POC. I've joined and have confirmation that my experience will allow me to run in the time trials without having done the short track series. With a cup air box, cat bypass and secondary bypass I run at 89-90 db, comfortably under the normal 92 db limit and sqeeking by on 90 db days.
I've run at LS about 10 days in the past 2 years and am pushing to get below 1:50. I know that Kary and Martin are a bit below that, but I think Karey cheats and uses slicks and I only have MPSC tires. (excuses, excuses ...)
I figure that if I'm crazy enough to drive 4.5 hours to get to Buttonwillow, it would be well worth the effort to go 5-6 hours to get to LS. I hope to see you there.
i think a drilled airbox and a cat bypass gives the perfect sound to a car thats going to be used everyday. Doing the g-pipe too is perhaps a bit loud for the day to day stuff, but fantastic for a second car. I am a little concerned about certain trackdays, although i got onto silverstone this year with no problems, and some cars there were almost twice as loud. I think a lot of people worry about being tested at trackdays in the uk, but of the 20+ uk days i've done, i've only ever been tested once.
Super Duper Moderator
I have a cup airbox (the expensive drilled version
) and a g-pipe and use it as a daily driver. No noise issues but it might be different in a cabrio versus my coupe.
I have been to the track (once so far) and had no issues with noise. I was also told that, while mine was not the loudest car, it was certainly the distinctive for being an air-cooled 911!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Marc
Marc
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Originally Posted by Tom W
Garrett: I drove from San Diego to my home (497 miles) in about 7 hours and Monterey is about 1.5 hours south of Half Moon Bay. I'd guess more like a 6 hour drive. You should come to Laguna Seca for the POC event so I have someone to play with (is your car KP too?). It is a wonderful track to drive. I think a double apex at turn 2 with a big throttle lift to rotate the rear end is the most fun turn on any track I've driven.
Gary: I've done the dual outlet Fabspeed exhaust to replace the primary. It gave 10 hp less than the cat bypass and secondary bypass. If you want power, save your money. If you want load (as in illegal in CA at 96+ db), it's your answer.
Leo: If the thing on your car has a heat shield attached to it, it's a stock cat. If there is no heat shield, it may be a cat bypass. If you do a search you'll find some pictures of the cat bypass.
Jim C.
Thanks for the input on the noise of my current setup - I was thinking I would have to reinstall the secondary muffler, but apparently not! Maybe I'll bring it just in case!
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The only time this approches being "loud" is when I go WOT, then the sound of the (lack of) airbox chimes in. Personally I LIKE the sound this Fabspeed puts out, and cruising is no problem at all!
Originally Posted by badcar
My Fabspeed sounds amazing.
It sounds awesome at idle and pure magic on a wide throttle.
Regards
Dave
badcar- is that the aftermarket driver's side rear panel with the pipe cutout or did you just cut out a spot for it with the sawzall? How about some more pics of that setup or better yet, an audio file?
c
c
I have a slightlty modified exaust on my 964 RS, more bypasses. The heater is desabled and I therefore want to replace the original headers with some without this heater things build around it.
Where can I get them?
