anyone have a bigger rear sway bar FS?
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
I am looking to do some suspension changes... does anyone happen to have a used rear sway bar they are interested in selling - preferrably an adjustable one...
What does the stock C2 come with in the rear? Isn't there issues with confinement in the adjustablility and fit with sway bars on the 964? I thought that the adjustable was not really all that adjustable because there wasn't enough room to use the different settings?
Duncan
Duncan
Duncan
Duncan
18mm: 964.333.701.70 Carrera 2 RS only
19mm: 964.333.701.12 Carrera 2 M249 (tiptronic)
20mm: 964.333.701.06 Carrera 2/4 91- M481 (manual)
21mm: 964.333.701.07 Carrera 2 -90 M481
Super Moderator
Needs More Cowbell
Needs More Cowbell
Here's one from a Cup:
120 964 Carrera Cup/RS Rear swaybar N.O.S. $175
http://www.porsport.com/images/2004_1108/Im002160.jpg
http://www.porsport.com/parts_for_sale.htm
Super Moderator
Needs More Cowbell
Needs More Cowbell
According to http://www.cupcar.net/92cup.asp (JC in NY),
24mm 5 way adjustable front anti-roll bar
18mm 3 way adjustable rear anti-roll bar
guys,
im have just swapped my turbo rear arms for NB ones and have been looking for a sway bar.
The turbo one is 22mm - bigger than the NA cars i guess due to the extra weight no? but this wont fit now as its longer to match the wider turbo arms.
What i dont get is in 1990 porsche put a 21mm bar on the NA cars then after that a 20mm... and the RS 18mm are we saying smaller is better here?
I was aftter quite a stiff setup with minal roll as poss.... just thinking i could make the 20mm bar i just bought into an adjustable one.
im a bit
im a bit
