J-McDonald & Melissa
Just to say than you for the info on the ignition wire arcing, i have managed to fix my flashing warning lights syndrome which has plagued me for the last 4 months.
Thanks for your time
Best Regards
Rob
91 C2 Cab
Best Regards
Rob
91 C2 Cab
Hi
I had replaced the ignition wire running from coil to dist cap as it was corroded at the dist cap end. Also removed the dist cap and found the the voltage had scarred the dist cap plastic, rubbed it down, polished it and re varnished. Voila no arc and no more embarrasing warning lights.
thanks again
Rob
another cab owner was having the same problem so i have emailed him privatly, so hopefully thats 2 happy people.
thanks again
Rob
Rob,
Congratulations! I love a happy ending, and I know what a drag these intermittent electrical problems can be. Glad you solved your problem (but I'm sure I'm not nearly as glad as you are. )
And I see that you're already passing the news onto others to help them solve their problems. Good job!!
-- Melissa
-- Melissa
