964 a/c bracket
964 a/c bracket
I'm putting a 964 engine (no ac) into my '88 and want to keep my ac compressor. it doesnt appear that my mounting bracket will work from my 3.2. any thoughts?
if I source a used 964 bracket... are they all the same? thanks!
-bernie
-bernie
Unfortunately the 964 has two brackets, one for A/C (964-126-026-00) and a chopped (non-A/C) version (964-115-011-02).
Here is the bracket for the A/C compressor
and here is the chopped non-AC bracket:
Jason,
Thanks for the response! After a good bit of searching yesterday... I found that out for myself. Now I just need to source the A/C version so I can get this puppy back together.
-Bernie
-Bernie
Garrett,
My car came with the shortened (non-A/C) bracket from the factory so I have no idea and I've had no luck finding the bolt in PET. I suppose I could remove it and measure but I don't know what it attaches to and with my luck...
Spotted this on Ebay and know it's what you are after! Shipping should not be too expensive as I have shipped items to the US lighter than this item for around £35.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...560610928&rd=1
Hope this helps.
Adrian
Hope this helps.
Adrian
adrian,
thanks for the link. since it was holding up my 3.6 swap, i ended up buying one from a used parts place here in the states. in this case, it was worth a little extra $ to get it here... arrived today.
thanks again,
bernie
thanks again,
bernie
