964 Forum 1989-1994
fan belt light
Old Jun 27, 2005 | 05:07 PM
david@st ives's Avatar
david@st ives
Default fan belt light
does anyone know why the fan belt light on the dash comes on intermitently
,i have checked the tightness of the belts and they seem fine ,i have two belts with no air con is two belts correct i dont think there is anything missing any help
thanks
dave
Old Jun 27, 2005 | 05:12 PM
jimq's Avatar
jimq
Burgled
The little wheel on the sensor that rubs on the belt may be sticking or worn out. Sorta common problem.
Heirsh's Avatar
Heirsh
the sensor is a little cam that rides on the belt on the left side. It could be set wrong, so it pops between on and off. It kinda looks like a tensioner; it just rides ont he belt and when it breaks it pops forward triggering your dash light.
Also this is one of the lights I had go off by itself when I had high voltage leakage problems. More commonly I had full dash christmas tree lights. I wouldnt think this is your problem, but just mentioning it.
Old Jun 27, 2005 | 05:21 PM
bhensarl's Avatar
bhensarl
Jarhead
Might just check the electrical connection on the sensor itself. Give the plug a good cleaning and see if that helps things.
Brian
Old Jun 27, 2005 | 11:38 PM
Richard Curtis's Avatar
Richard Curtis
if you need to replace the fan belt sensor, it's about a 5 minute job and VERY easy to do. the sensor is available at Porsche shops.
Old Jun 28, 2005 | 12:47 AM
LA964RS's Avatar
LA964RS
What they all said!....I'd guess needs replacing...better for peace of mind. Scares the sh*t out of you when it comes on doesn't it?!
Old Jun 28, 2005 | 12:34 PM
Richard Curtis
Yes, it does scare you. When mine came on, I was about halfway between Houston (where I picked up the car) and home. My son was with me, and I put him to work quickly reading the owner's manual. Stopped the car, saw the belt was still intact and kept on trucking.
Old Jun 28, 2005 | 01:31 PM
Heirsh's Avatar
Heirsh
I would imagine you'd hear that belt break. Of course if you have bypasses in place and set off car alarms normally as you drive by you might miss it :/
Also if the temp starts rising you have a good clue. I love having real guages again. Manufacturers have gotten to putting nothing but idiot lights in cars. My VW Golf knew pretty much everything going on in that ar, but to find it out I had to plug a darn computer up to the ecu. /sigh
