964 Forum 1989-1994
Which track pads? Pagid, Hawk, Porterfield, PFC OR Carbotech?
Old 06-20-2003, 01:09 PM
joey bagadonuts
joey bagadonuts's Avatar
Thumbs up
Thanks, David. Good info.
The message I got from reading the white paper is to always bed in your pads ... even if they're used. I wasn't aware that adherent friction was the result of having the same material on both the rotor and pad, but now that I do, I can see how swapping compounds requires proper bedding in.
I guess life gets a lot easier when you find the brand you like and then stick with it (no pun intended).
Old 06-20-2003, 07:29 PM
Robert Linton
Robert Linton's Avatar
Post
Without hesitation, Pagid!
Old 06-24-2003, 10:08 AM
Strabo
Strabo's Avatar
Post
Interesting comments. I did not see ay comments about the Pagid orange break-in procedure. If you do not follow their instructions precisely, the pads can leave a deposit on the rotor. That deposit is ultra-hard and caused the rotor to heat unevenly. Warped rotors are a common result. I switched to Hawk blue because of this. Hawk blue also do not squeal as bad as the Pagid orange.
I'll be interested to try Pagid yellow. Does anyone know if they require the same break-in procedure?
Strabo
Old 06-24-2003, 12:05 PM
JW in Texas
JW in Texas's Avatar
Post
Strabo,
Pagid advises the same break in procedure for all of the racing compounds. I have always bedded them on the track without problems. <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old 06-24-2003, 11:05 PM
Greg Fishman
Greg Fishman's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by JW in Texas:
<strong> Hey, if they are good enough for the Racer's Group & several other teams, </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">They don't use them. I asked my mechanic about the yellow's and the only GT3RS teams he knows of using them are AJR. Most are using PFC's.
Quick Reply: Which track pads? Pagid, Hawk, Porterfield, PFC OR Carbotech?
