Airbag Fault Code 029
Technical Guru
Left front sensor - Line resistance too high
Check front sensor at plug connection with ohmmeter .
1. Ohmmeter at terminal 1 and terminal 2
Display: 10 kOhms
2. Ohmmeter at terminal 2 and terminal 3
Display 0...0.5 Ohms
If measured values are within tolerance, renew the control unit; if out of tolerance, renew the front sensor.
Hopefully you only need to clean the contacts...
Display: 10 kOhms
