964 Forum 1989-1994
Torque Settings?
Old Jun 12, 2003 | 05:32 AM
Pete 90 C4's Avatar
Pete 90 C4
Question Torque Settings?
Hi All,
Can anyone tell me the torque setting for the six in-hex bolts that attach the rear half shafts to the diff/gearbox on a 1990 C4 Coupe?
Many thanks in advance,
Pete.
Old Jun 12, 2003 | 12:47 PM
91C2wrencher's Avatar
91C2wrencher
Post
We're not ignoring you. It's just that my little tech book doesn't exactly answer the question. It looks like if they are attached with M8 threads the rating is 42Nm and if its a M10 its a 80 Nm. Not quite sure how that helps you. but the descrition in the book is "Drive shaft to rear axle final drive" HOLD ON! just found something under "engine/trans spec" reads "Drive shaft to transmission flange" 42Nm. so there ya go.
Old Jun 12, 2003 | 12:58 PM
Pete 90 C4's Avatar
Pete 90 C4
Post
Thanks very much - I can go for a spin tonight now! <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
Old Jun 12, 2003 | 05:16 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">code:</font><hr /><pre style="font-size:x-small; font-family: monospace;">Tightening Torques for manual transmission G 64
Location | Thread | Tightening torque Nm (ft.lb)
Oil drain plug and oil filler M22 x 1.5 30 (22)
plug
Hexagon nut for gear and M8 23 (17)
transmission cases, side
transmission cover,
transfer case,
intermediate case,
tensioning plate
Clamp plate to transfer M6 10 (7.5)
case
Lock nut / driver carrier M24 x 1.5 240 (177)
Lock nut / bearing carrier M42 x 1.25 300 (221.5)
Hexagon head screw / M8 23 (17)
shift fork
Collar nut / input shaft M14 x 1.5 140 (103)
Reversing-light switch to M18 x 1.5 35 (26)
gearbox
Guide tube to M6 10 (7.5)
transmission case
Shift gate to tensioning M6 10 (7.5)
plate
Mating bearing screw / M30 x 1.5 80 (50)
engaging forks (interaxle
lock)
Collar screw / reverse M8 35 (26) (and loctite 270)
idle gear II
Bleeder in transmission M14 x 1.5 35 (26)
case
Mating bearing screw / M12 x 1.5 65 (48)
engaging fork (rear-axle
lock)
Collar nut /input shaft M30 x 1.5 250 (184.5)
Lock nut /drive pinion M40 x 1.25 240 (177)
Hexagon head screw / M10 44 (32.5)
halfshaft flange
Tension spring / M6 10 (7.5)
tachometer sensor
Crown wheel to M12 x 1.25 150 (112)
differential housing (hex
bolt with tab washer)
Crown wheel to M12 x 1.25 200 (147)
(Verbus-Ripp bolt
WITHOUT tab washer)
Cover on differential M6 15 (11)
housing
</pre><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">
