accelerometer part numbers please
I am in need of new accelerometers...I've looked through Adrians book but couldnt find a part number. Does anyone have a part number for me so I can reference it.
Anyone know where I can get 2 without investing a small fortune?
993.606.153.00 - Side Acceleration Sensor? It's number 4 on the pet diagram and there is two of them. Illustration 901-04. Unfortunately I am not smart enough to figure out how to post a page from my PET cd. I hope this is what you are looking for.
You could try eBay or one of the dismanteller's. I have had a lot of luck with 20th Street Auto Parts in Arizona.
Is it this piece? http://forums.pelicanparts.com/show...threadid=221370
Or is there a part number on the case?
I did a forum search and that's how I found this link, but it is sold.
Jarhead
The Bosch part # printed on the lateral accelerometer is #0 265 005 100. That's the number for part #99360615300, just like it says on the PET page above.
Brian
Brian
Craig... Try "Screen Grab Pro" v1.2... It's freeware found on the net. just open the program, hit the F9 key, use your cursor to capture the area you want, then name the file and where to store it.
It's a neat program....
Super Duper Moderator
I use SnagIt, a shareware from www.techsmith.com. Never tried Screen Grab Pro but freeware is always cheaper than shareware. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Marc
Marc
Technical Guru
You can also use the Print Screen "Prt Scr" key on your keyboard and if you use the alt key as a qualifier just the active window bitmap is copied to the clipboard.
My car fixer has tried to clean them 2 times...but the one keeps failing intermitently. Should I try another cleaning method?
First try was cleaning fluid being sprayed...no air pressure was used to blow out the part.
Technical Guru
