964 Forum 1989-1994
Adjust valves to what value?
Old Oct 8, 2002 | 12:10 PM
steve_eo's Avatar
steve_eo
Question Adjust valves to what value?
I've read the very useful descriptions about adjusting valves in the archives. I have but one question. What thickness of feeler gauge do you insert into the valves?
Did I miss something in the articles about this?
Is there a special feeler tool from Porsche that has the correct thickness?
Old Oct 8, 2002 | 12:57 PM
warmfuzzies's Avatar
warmfuzzies
Smile
I guess there must be "a" size as this
<a href="http://www.type-911.co.uk/images/specialisttools/fgt.jpg" target="_blank">http://www.type-911.co.uk/images/specialisttools/fgt.jpg</a>
only shows one gauge.
Old Oct 8, 2002 | 01:18 PM
Taj's Avatar
Taj
Post
0.1mm inlet and exhaust when cold according to the workshop manual.
Taj.
Old Oct 8, 2002 | 01:38 PM
steve_eo's Avatar
steve_eo
Post
Thanks for the info.
0.1mm is what I'll adjust to.
Regards,
Steve
Old Oct 8, 2002 | 03:09 PM
sullivs's Avatar
sullivs
Post
After you adjust your valves, what torque will be used on the valve covers? I have heard conflicting stories on that one.
Steve
Old Oct 8, 2002 | 03:19 PM
mojorizing's Avatar
mojorizing
Post
Hi Steve OOOO!
Go to <a href="http://www.geocities.com/serverdude911/Porsche/index.htm" target="_blank">Everything you wanted to know about valve adj. but were afraid to ask webpage</a>
Good info for DIY'ers
Old Oct 9, 2002 | 05:56 PM
sullivs's Avatar
sullivs
Post
Thanks. Looks like good stuff. The most common answer I have found is 8 to 10 ft.lbs.
Steve
