RS America A/C retrofit question..
Hey all,
My father has been looking for an RS America and wants a low mileage (read: perfect) car. He claims that most he has found have 0 options or all of them. He was wondering if he finds the *right* car how hard it would be to have A/C installed if it doesnt have it. Are any aftermarket kits available or by the 964 did Porsche actually get the A/C nailed down? (my 951 a/c failed numerous times before I yanked it altogether) Would it be easy enough to install a factory 964 setup?
(The A/C would be more a requirement for my mother when she drives the car.)
thanks!
thanks!
Super Duper Moderator
Marc
I don't know if it would be economical to add AC to a 964. I would assume that you would need a new/used CCU w/AC, all the lines, condenser, evaporator, compressor, mounting brackets, relays, and probably things I'm forgetting. Plus does anyone know if the harness would have everything he needs?
IMHO, your father should just get a "loaded" RSA that has everything installed at the factory. That way you would know it's right and installed correctly.
I'd think that there are some used RSA A/Cs out there because some track junkies removed the whole system long ago. Mine still works fairly well on the old R-12, but then I don't live in Arizona either.
good to know - he likes what he likes. RSA's is one of them. Cant knock him for taste. thanks for the help - the search shall continue.
