964 Forum 1989-1994
Brake Line Identification Help
Old Dec 30, 2002 | 10:26 AM
Robert Coats's Avatar
Robert Coats
Post Brake Line Identification Help
The parts catalog I have shows the rigid brake line that goes between the front brake caliper and the mounting tab on the shock is the SAME for left and right sides, but can anyone confirm this? Are the left and right brake lines the same?
-Robert (who, during a spring install yesterday realized the brake lines were not going to survive the removal procedure, and thus, twisted themselves into horrible little scraps of metal)
Old Dec 31, 2002 | 12:02 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Post
Your looking at the wrong line. You want
964.355.582.03 - Right
964.355.581.02 - Left
Old Dec 31, 2002 | 01:18 AM
Robert Coats
Post
[quote]Originally posted by JasonAndreas:
<strong>Your looking at the wrong line. You want
964.355.581.02 - Left</strong><hr></blockquote>
Ah-ha! I KNEW the lines were different. Thanks!
Old Dec 31, 2002 | 04:36 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
Robert, FWIW, you have the crossover pipe from one side of the caliper to the other circled.
Good luck on your spring install...so...who's procedure ARE you using?
Old Dec 31, 2002 | 08:16 AM
Robert Coats
Post
[quote]Good luck on your spring install...so...who's procedure ARE you using? [/QB]<hr></blockquote>
Yours has been my "guiding light."
So far, I've gotten the front springs installed on the old struts, and, since I only have one pair of jackstands, decided to first complete the front before moving on the rear. So, I've got to call the dealer today and hope he's got those brake lines in stock. With luck and parts, I hope to be on the road by Friday-ish.
