Need help with rattle
Has anybody experienced a small rattle coming from the driver's window/door? Lately I've noticed a noise that seems to be coming from the window but I can't isolate it by pressing on the window or any of the door panels. I've made sure all fasteners are tight. It's very minor but just knowing I can't fix it is going to drive me nuts.
Thanks for any help.
Specialist
I think the only way to find this is to take off the door panel. One thing that comes to mind is the crossover for the speakers, but could be many things...
I had a similar rattle, turned out to be the window winder mech. I took off the door trim and carefully cut the pastic liner then gave the mech a good grease. Sealed up the plastic liner with Duck Tape.
Originally posted by John K:
<STRONG>Has anybody experienced a small rattle coming from the driver's window/door? Lately I've noticed a noise that seems to be coming from the window but I can't isolate it by pressing on the window or any of the door panels. I've made sure all fasteners are tight. It's very minor but just knowing I can't fix it is going to drive me nuts.
Thanks for any help. </STRONG>
Thanks for the responses. Is the door panel a PIA to remove? I've found the screws to remove the top piece at the bottom of the window. Does the door panel just pop off?
Thanks again.
Thanks again.
