Dash Lights not working.
Anybody know the fuse number for a 90 targa for dash lights. My dash lights are out. I hope it's just a fuse. Neither Adrians book or the fuse diagram tells if there is a seperate fuse or the number. Would save me lots of time. Thanks in advance!
If you have NO lights it would be useful to find out what else does or doesn't work. No lights at all sounds more light a ground fault or a problem with the ignition switch itself.
It's pretty easy to check ALL the fuese - there is a continuity check inside the central electric fuse box.
Do any of the ignition related lights (stop lights?) work. Blower fans??
I think we need more help here.
Regards
Dave
Regards
Dave
Do you mean the dash instrument illumination lights ? or the "warning" lights ?
Fuse 18 in the front trunk fuse box is the dash instrument illumination and central informer fuse. The instrument illumination is also controlled by a dash mounted intensity control. check it's not turned all the way down.
