Relay's
Relay's
Hi
I have a 964 C2 Cab, no air con.
I have the following relays missing
R3, R13, R14, R32, R44, R51
I know some of these are meant to be empty, but a couple of them have made me wonder. If anyone could tell me what is essential i would be grateful.
Regards
Rob
Regards
Rob
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Rob,
None of these relays are used on your Cab.
R3 Not Used
R13 Not Used
R14 Condenser Blower (not needed)
R32 Warning Flasher USA (not needed)
R44 Catalytic Converter Monitor (not needed)
R51 Brake Booser Pump (you do not have this installed, not needed)
Hope this helps,
Ciao,
Adrian
911C4
PS: Less weight to carry around. This is good.
R3 Not Used
R13 Not Used
Hope this helps,
Ciao,
Adrian
911C4
