H4 Headlight quest
H4 Headlight quest
I'm missing some pages in my owners manual and changing bulbs are one of them.
Can anybody explain me the procedure to replace the bulb in a H4 headlight pls ? I've already unscrewed the screw at the bottom that holds the ring. what's the next step pls ?
Thanks !
WSP964
Thanks !
WSP964
Undo the small screw at the bottom of the headlight trim. Pull off trim ring. Pull from the bottom of the ring as it is hinged at the top. This can be very stiff so a large flat blade screwdriver can be of use here, use some card to protect the paint.
Once the trim has been removed undo the screw at the bottom of the headlight assy, the one the little screw screwed in to. Pull out headlight assy using similar technique as above.
Easy really
[quote]Originally posted by Wsp964:
<strong>I'm missing some pages in my owners manual and changing bulbs are one of them.
Thanks !
WSP964 </strong><hr></blockquote>
Easy really
Thanks !
