window regulator, how hard to replace?
Looks like the left regulator has given up. How hard is this to replace? Is it pretty much self- explanatory once you remove the door panel? Thanks....
Drew
89 C4
86 930 (just finished front suspension rebuild)
Drew
89 C4
Hey Drew,
Wayne Dempsey's "101 Projects for Your Porsche 911" has a project that includes removing the window regulator. For a 74-89 911, as I recall. I plan on using this and a PET printout to replace mine--someday.
Has your window quit working altogether?
In my case, I was having a problem with the driver's side window not lowering (stuck all the way up) on an intermittent basis (say, once every 2 months). After driving a short while--or a few days later--it would decide to lower. The relays, switches and power all checked out okay. The last time the window acted up (August of last year), I used the manual handcrank to free it, and it hasn't stuck since. However, when the window is about 1/3 down, it now rattles when hitting bumps.
I purchased my new regulator from Sunset Porsche for $135, using the Excellence magazine cost + 15% discount (it's still sitting in its box, ready for installation). I doubt you'll find it cheaper than Sunset's price.
Too bad you don't live closer. We could have a regulator replacement party, knocking both out at the same time.
Best of luck.
Best of luck.
