grinding going from 2nd to 3rd gear at high revs
I was very happy to see that this is a fairly common thing, a slight gear nash from 2nd to 3rd. What I do is press the clutch in all the way, into neutral, blip the throttle a tad,and then on up into 3rd, no rushing it .... that stops it. I am going to change the gear oil to the synthetic though, what the heck, why not.
1990 964 c2
1990 964 c2
Mine does the same on the track when the gearbox is hot. I think slowing it down and properly using the clutch all the way will reduce the grinding.
I also noticed the same grinding when downshifting if I didn't match the revs enough. It sometimes happened when executing that 5th to 3rd shift because it was harder to get the revs up accurately when you're threshold braking from 140mph to 40 for a corner. Getting those revs just right while stomping on the brakes HARD is tough to do!
'93rsa 3.8
