indicator stalk does not self cancel...help!
Hi All,
Today my indicator stalk will not self cancel (left or right).....I think I need a new one. To replace it I need to remove the airbag from the steering wheel. Is there a procedure to follow so that the airbag warning light does not light up afterwards.....be nice if the airbag does not deploy itself in the process too!
Cheers........simon
Cheers........simon
When I bought my C2 in Feb., in order for it to pass inspection, I had to repair my turn signal. I had my mechanic tackle it while doing the valve adjustment. He disconnected the battery overnight and disconnected the airbag and just stuck a piece of plastic rod in the mechanism which was a quick fix, but has held up nicely.
