How smooth should gear shifting be?
Skippy
When changing gears it feels like I encounter some small resistance. I cannot remember if my previous C4 had this aswell, hence the question. Engaging needs also some effort. I've been through the archives and found that a clutch slave bleed and perhaps a replacement of the gearbox oil with Mobil seem like first things to do. Clutch, clutch fork without DMF was replaced 10.000 kms ago, I suspect the slave was also replaced but I'm not sure about the French term they used to discribe it on the bill.Tx.
Super Duper Moderator
I had a little notchiness and resistance, especially with the 1-2 shift. Now smooth as butter after a clutch master/slave cylinder replacement and fluid change/bleed. I've got 58k miles on the car and the clutch was done by the po at 38k miles.
Marc
Marc
