How easy is it to adjust the brake pedal?
Jarhead
Originally Posted by garrett376
whew... I was thinking that so-called "service" sure did a lot more than maintenance!!!
Brian
Technical Guru
You can change the brake pedal height by adjusting the push rod behind the clutch pedal. Just remember to check your brake lights and adjust the switch accordingly. Now if I could only figure out how to hook these up to my pedal assembly, only $731USD.
Originally Posted by CraigyB
Once saw someone solve this by sticking a block of wood/plastic material to the top of the accelerator, crude but effective...
The reasoning behind it is here. Quite some time later I'm still very satisfied with it
Oh, and the wood has been screwed on, not stuck or glued Wouldn't want it to come off accidentally
Cheers,
JW
Super Duper Moderator
I bought the race set (in black) and really like it. I got the standard black pedal shown in the photo above but replaced it with the fully adjustable one in black and it is great. I use the smaller lower wing as a larger one comes with it too but I found it too large with my size 11 feet.
Brian - honest - I'm not holding out. The car is the photo looks really nice (like the look of the steering wheel too) but it is not mine. I wouldn't hold out on the group like that -- you people are the only ones who can understand why a US$250 accelerator pedal is a "necessary" purchase.
Marc
Marc
Originally Posted by JW Hubbers
That might have been me
Cheers,
JW
Cheers,
JW
Here's an idea, try painting the wooden block add a logo or manufacture out of some exotic material, then sell for $100 !
Yeah JW, I'm sure it was now. Anyhow that gets my vote !
This piece of wood was supposed to be a proof-of-concept/prototype to see if I wanted it any thicker/thinner or wider/narrower. As it turns out this feels just right, and I never got round to taking it out again and painting it black
By now I've gotten used to it, and I can't be bothered to invest the time in cosmetics
Cheers,
JW
