Ouch! loud valve noise
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
Hi all,
Just got back from a DE in Mid-Ohio. Great time! with one exception.
During the last session, I went to pass another car and hit the rev-limiter in third gear
. After finishing the session and pulling into the pit, the valves on the driver's side were obnoxiously loud.
The car is very much drivable, but the noise is unbearable. Any ideas, as to what it may be? I'm hoping for the best (a broken valve spring???
), don't even want to start thinking about the worst case scenario...
The car is a 91 C2 with 133,000 on the odometer, engine has never been touched. Car uses about 2/3 of a quart of oil between oil changes (every 3000 miles). Minor leaks, just a pea sized drop on the garage floor after driving. Doesn’t smoke.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
If the rev limiter worked, it is hard to imagine the overspeed damaged anything major. My money is on a broken valve spring, or possibly a broken rocker. The latter would cause a bad miss, so the valve spring is the best bet. They can be changed without pulling the heads. By all means do the compression test and report back.
Jarhead
As long as you don't mean, "I hit the rev limiter... due to an untimely downshift" it shouldn't be anything horrific. Here's hoping it's relatively minor.
Brian
Brian
The valves are due for an adjustment, but this sounds a bit louder than average. The over-rev was definately not due to a downshift, but hit on acceleration in 3rd gear.
We'll see what tomorrow brings...I had no choice but to drive the car 400 miles home
, stayed under 3000 RPM hopefully didn't cause any additional damage
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Originally Posted by siberian
Hi all,
Here is a link to an audio file of what my engine sounds now at around 3000 RPM, half way through the middle I let of the throttle and let it idle for a bit. What do you think??? ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
ENGINE SOUND CLIP
ENGINE SOUND CLIP
Tonight I checked the distributor belt. All is intact. Both rotors are rotating insynch while I manually turn the fan.
I'm praying for a busted valve spring...will find out later in the week, after I open her up...
Professor of Pending Projects
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
ENGINE SOUND CLIP
ENGINE SOUND CLIP
That is bad. If it was me, I would do the following. Don't run the car anymore that necessary. Perform a compression test check to see if the the valves are bent. Perform a leak down test to see isolate it down further to intake or exhaust valve. If both compression and leakdown are good, then pull the valve covers to inspect the valve train including valve spring and rocker arms.
