Radio Replacement - Speaker wiring?
The original radio in my RS America did not work when I purchased the car. I am just getting around to replacing it with a blaupunkt CD player. The CD powers up fine, but no output through the speakers. And I also connected an old blaupunkt Reno and again, nothing. I checked the speaker wires for continuity and to ground and there is no connection. Before I start pulling door panels off to check to ensure the wires are plugged into the speakers, anything else to look for (something unique about the way the RSAs have their radio wiring installed)?
Originally Posted by investlt
Did you check to see if you had an amplifier under the passanger seat? If you have one, then the speaker connections are there, and the amp connection is in the dash.
I made a weak attempt at pulling off the speaker covers, but it looked like a risk of breaking them. Are they just a snap fit on the RS door panels?
Thanks guys,
I did pry off the speaker covers - a little bit of an effort to snap them off w/o breaking off the plastic clips.
Both speakers were completely blown out. Replaced them and now the radio works fine. Too bad the exhaust is too loud to hear it while the engine is running.....
