strange suspension thing
Jeff
my ride height is fine as measured from the prescribed measuring points at front & rear. However, as described, the rear right is 'off' a bit, both via fender lip measuring to ground AND by the amount of adjustment needed on the spring carrier C-nut on the damper.
However, my sway bar seems a bit stronger than yours!!!
