ASHTRAY DOESN'T STAY CLOSED!
Anybody have this problem. Not quite sure how the ashtray is supposed to work properly since it was like this when I bought the car(90 Targa). Any thoughts on fixing it, part #'s etc. would be greatly appreciated. Thanks!
Super Duper Moderator
Yeah, mine is a pest too. I have to try closing it several times to get it to stay closed. Another thread suggested removing the liner in the ashtray but that did not help - you could try that. I just leave it closed (and tell passengers to keep their hands to themselves as they always want to poke around).
Marc
Marc
Join the club! I think anyone who uses their ashtray has this problem. If you look on the right hand side you will see a little arm sticking out that has a little tip sticking out toward the ashtray. The tip needs to be pushed back into the track and it will work again. It's easy enough (And I have had so much practice fixing it!) that I can fix it while driving down the road. I'm a smoker but don't use it as an ashtray... I keep my lighter in it. The key is to open and close it slowly and carefully. I can post a picture if you think it would help.
I don't use the ashtray, my problem is it will not stay shut. Do you think replacing it with a new ashtray will fix the problem. It bugs the crap out of me that I cannot shut the darn thing!!!
Nope... You just need to put the tab back in the track. Here's a picture to show you what I mean.
You can see how the arm with the tip rides in the track. It's a lousy design... The tip is too short. If you push it too hard while opening or closing it... The arm pops out of the track. Take a small screwdriver and pop the arm back in the track! It can be a little maddening until you do it a few times. If you can't do it in the first three tries... STOP... Consume three of your favorite alcoholic beverages... Then try again!
Good luck!
EDIT - Uhh... Sorry for the x-rated lighter. Don't mean to offend anyone.
Good luck!
WOW........@ 1002,000 mi. mine started staying open,never had the problem till two week's ago!
thank's Smokin....just another somethin to keep one their toe's.
Jim
Jim
Rick - thanks for the tip but it still does not work. I usually have to slam mine to get it to stay closed.
The little tip in the track you are referring to does not slip into the notch to keep the ashtray closed (circled in red, below). Neither the tip nor the track looked worn - any idea why it is not slipping into that notch?
Marc
Marc
Last edited by Marc Shaw; 07-23-2005 at 10:10 PM. Reason: edited out the naughty bits on the lighter
Marc... This is a stupid question... But are you sure it's actually in the track? There are sometimes where mine looks like it is, then when I push it closed it pops out before closing. I took a pair of needle-nose pliers and bent mine in toward the track a little. I would imagine that too much force, however, would break it. You can see in the picture that my tip is almost out of the track as it is! I need to work on it a little more. If I handle it very carefully it works... But too much of a push when opening or closing will pop it out every time.
Also... Did you drink your three beverages?
Technical Guru
Technical Guru
Originally Posted by Smokin
Jason... Was that hard to take out? I've never tried.
Lifetime Member
Lifetime Member
This is mentioned in the book, 'The Used 911 Story - (Excellence was Expected, but...)', but this is the first time I ever heard anyone actually mention it elsewhere.
Good luck!
Good luck!
Hi Smokin, thanks for sharing this info & pics with us! Very usefull.
And now I know why you call yourself "Smokin"
Greetz
I had the same problem with mine. I removed the tray and put two pieces of electrical tape oppisite the small arm with the tab on it. I forces the tab into the slot a little more and helps to keep it closed. Mine used to pop open on every bump but now stays closed. Be aware it may make opeing the tray a little harder but it seems to work to keep it closed.
