964 Forum 1989-1994
Fuel Pump Hum
Old 02-04-2003, 06:53 AM
johnfm
johnfm's Avatar
Post
MDH
I think 40-42 is still lower than spec:
SPECS:
at idle
3.3 bar + - .2 bar = 44.95 to 50.75 psi
jumped relay
3.8 bar +- .2 bar = 52.2 to 58.01 psi
Maybe your FPR needs a look at too!
Did you check these yourself or did the gararge do it??
EDIT - ANOTHER QUESTION
These pressure specs - are they measured before or after the Fuel Pressure Regulator?? If the specs are downstream of the FPR, which they must be if taken at the fuel rail, is there a test point for BEFORE the regulator??
Quick Reply: Fuel Pump Hum
