964 Forum 1989-1994
Stainless steel brake lines
Old Sep 12, 2005 | 12:10 PM
puma1824's Avatar
puma1824
Originally Posted by Wachuko
So much for getting the car ready for Thursday... since I am doing all the work on the brakes, calipers are out, etc... might as well change the stock lines for new ones. I went ahead and ordered the lines from AJUSA.
Thanks for the link puma1824!
No problem...just ordered my set too.
Anyone have proceedures on how to replace the lines?
-Puma
Old Sep 12, 2005 | 12:29 PM
ddz's Avatar
ddz
Is there a link that someone could provide on how to properly bleed the brakes/hydraulic system on a 964? Can power bleeders be used to flush out the ABS and traction control circuits? Are they independant or do you need to bleed both at the same time? I think I read somewhere that the only way to bleed the differential lock actuators was to go to a shop with a Hammer that could cycle the locks. Could you do the same thing by engaging the diff lock switch on the console('89 C4)? Finding a shop in Western Mass that has a Hammer has not been easy.
Old Sep 12, 2005 | 01:23 PM
warmfuzzies's Avatar
warmfuzzies
The SS lines should have a PTFE liner, which is not so suseptible to the damage and swelling the rubber ones are, I had two rubber ones fail on my 10 year old Audi during an MOT, I couldn't see them myself, but was shown them on the MOT by the tester, frightened the life out of me...
kevin
Old Sep 12, 2005 | 06:06 PM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Overnight shipping for the brake lines... might still be able to have the car done before Thursday. woohooo!
Old Sep 12, 2005 | 06:11 PM
jimq's Avatar
jimq
Burgled
Geoff is staying at the Swan Hotel near Disney. What time are you gonna head out there? I have a big road design project due at work thursday so cant head out there until 5:30 or so. He is going to call me tomorrow. I still have your cell so will confirm plans if he doest talk to you first.
Old Sep 12, 2005 | 08:09 PM
puma1824's Avatar
puma1824
Cool. I ordered mine 3 day. Let us know what you think of the SS lines. You got the Kevlar ones from AJ right?
Old Sep 12, 2005 | 10:18 PM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Have a look here.
Power Bleeders can't flush the ABS or PDAS systems - you do need the Hammer for that. Diff lock switch alone won't do it, AFAIK.
Marc
P.S. A good place to find DIY stuff is the DIY Forum and the Search function ("Search this Forum" at the top of the forum).
Old Sep 12, 2005 | 11:20 PM
Wachuko's Avatar
Wachuko
Cool
Correct. Same ones you posted the link for. I will post photos in the thread I have with all the projects progress.
Old Sep 14, 2005 | 11:58 PM
puma1824's Avatar
puma1824
Did you get your lines yet? I received mine, only the longer lines have the D shape ends..is this correct?
How the installation go?
-Puma
Old Sep 16, 2005 | 10:56 AM
puma1824's Avatar
puma1824
Anyone elso know if the D shaped ends are supposed to be on the shorter set of cables? My set has the D shape of the two longer cables but not on the other pair.
Thanks,
Puma
Old Sep 16, 2005 | 11:03 AM
Wachuko's Avatar
Wachuko
Cool
Give me 10 minutes and I will post some photos. I got the same ones you did.
If I remember correctly the one with the notch/flat side goes in the front and the other one in the back. Let me find the photos.
Old Sep 16, 2005 | 01:55 PM
Wachuko's Avatar
Wachuko
Cool
Here you go...
After removing plastic cover from old line and placing in new:
Installed:
and yes... still have a lot of cleaning to do... but later when I am done...
Here is one of the rear brake line bracket. As you can see it is round instead of having a flat side.
Old Sep 16, 2005 | 01:58 PM
Wachuko's Avatar
Wachuko
Forgot the close up:
Notice the D.O.T stamp on the line... For 54 for the seat... heck... I think that is less than the cost of one original line.
Old Sep 16, 2005 | 03:16 PM
Marc Shaw's Avatar
Marc Shaw
Cool - I just ordered a set too so I'm looking forwards to getting them on.
Marc
Old Sep 18, 2005 | 02:42 AM
puma1824's Avatar
puma1824
Check out Wachuko's awesome step-by-step install with pics! LINK
-Puma
