Oil change procedure
John K- Thats the way I do it, drop the two plugs into two pans and wait overnight. Punching a hole in the top of filter would probably not be a bad idea, but I have not done it. One thing I do is jack up driver's side of car then set it back down gently,leaving the left rear wheel in positive camber, this creates a tilt helping filter drain, but I don't know if I need to do this.
well, get two oil drain pans.
also, instead of draining overnight, i let it drain while consuming approximately four adult beverages. this is an appropriate amount of time to let it drain.
Specialist
