964 Forum 1989-1994
MAShaw cooling ducts/fog lights installation guide.
Old 03-19-2005, 10:42 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Default MAShaw cooling ducts/fog lights installation guide.
MAShaw brake ducts/fog lights like "993 Turbo S" brake ducts. Come primed in gray fibreglass with 38 watt bulbs and a light socket (that can't be aimed). Are only for oil cooler and a/c condenser ventilation - and for looks - as there are no ducts back to the brakes.
While MAShaw's products seem very good, don't expect any installation help from them as they ignored all my requests for assistance.
Old 03-19-2005, 10:43 PM
Marc Shaw
Marc Shaw's Avatar
I made a template from cardboard to be able to get ducts fit in the right place (with and without tab). I wanted to make sure that the slot in the centre bumper was in the right place.
Old 03-19-2005, 10:44 PM
Marc Shaw
Marc Shaw's Avatar
Remove fog light and bumperette. I tied a string to the cables so they did not drop down inside the bumper and get lost.
Old 03-19-2005, 10:45 PM
Marc Shaw
Marc Shaw's Avatar
Start by cutting slot for tab on ducts -- this is the hardest part as the slot has to be in exactly the right place and it is very visible if it is messed up. It was hard to mark on the black paint so I taped a piece of cardboard in place and dremelled through it.
The best way I found to cut the plastic bumper is with a dremel flex shaft attachment. Go slowly as, if you cut the hole too big, you can't put it back in! Use the dremel to smooth the edges (and don't drop the bits inside the bumper as they'd be hard to get back out).
Old 03-19-2005, 10:46 PM
Marc Shaw
Marc Shaw's Avatar
Hole for duct is cut, wires moved over to that hole for safety and the hole started for light socket. Lots of dust!
Oh yeah - and cut those pesky bolts from the bumperette off flush using the dremel and a cut-off wheel.
Marc Shaw
Marc Shaw's Avatar
Trial fit.....it'll look better painted.
Old 03-19-2005, 10:47 PM
Marc Shaw
Marc Shaw's Avatar
Here it is - back from the bodyshop, freshly painted!
Old 03-19-2005, 10:49 PM
Marc Shaw
Marc Shaw's Avatar
I was concerned with bugs and other crap clogging up the oil cooler and a/c condenser so I covered the cooling duct opening with fibreglass screen made to fix screendoors (comes in black and won't rust!). Put a bit of double-sided mounting foam, folded it over tight, and secured with a zip-tie.
Marc Shaw
Marc Shaw's Avatar
I secured it in place with a stainless steel screw into the backing plate behind the bumperette and covered with a plastic cover used to cover screws on license plate frames.
The finished product.........now I just need to wash the rest of the car as only the new ducts/fog lights are clean! I'll try to get some better pictures once it is not snowing outside and it is sparkling clean once again.
Hope this helps someone.......Marc
p.s. Thanks Anthony!
Old 08-07-2005, 09:48 AM
warmfuzzies
warmfuzzies's Avatar
Default costs?
Marc,
Are these really $369/pair???? as they were the only ones I could find on MAShaws website.........
TIA
kevin
Old 08-07-2005, 12:17 PM
Marc Shaw
Marc Shaw's Avatar
kevin - Yup, they are the ones so that is the price....
I bought them new for a bit less from another Rennlister who decided on TechArt's instead ($1200/pair???).
Marc
Old 08-07-2005, 12:33 PM
warmfuzzies
Ho Hum,
thanks Marc, guess I'll have to bite the bullet then.............
kevin
Old 08-07-2005, 02:51 PM
jimq
Burgled
jimq's Avatar
I think we should try a group buy to get a better price
Old 08-07-2005, 03:54 PM
warmfuzzies
We could do, but I'm on the other side of the pond, so I'd need someone to send them to me.....
kevin
Old 08-07-2005, 03:58 PM
jimq
Burgled
jimq's Avatar
any interest??
Quick Reply: MAShaw cooling ducts/fog lights installation guide.
