Looking for 964 RS geometry settings
Hi all
I am desperately looking for the standard 964 RS geometry settings.
Am fitting a H&R coilover suspension to my 964 and want to adjust the geomtry to these settings:
camber front&rear
toe front&rear
castor front
I hope you can help?
Thanks a lot
cirpower
camber front&rear
toe front&rear
castor front
Thanks a lot
cirpower
Super Moderator
Needs More Cowbell
Needs More Cowbell
From Porsche Service Technik '92 911 Carrera RS, WKD 497 620, page 0-4, Technical data
Wheel Alignment
Front Axle:
Toe (total): +25' + 5'
Camber: -1deg +/-10', max difference left to right: 10'
Caster: 4deg 25' +/- 15', max difference left to right: 15'
Toe difference angle at 20deg steering lock: 1deg 50' +/-30'
Rear Axle:
Toe (each wheel): +15' +5'
Camber: -1deg15' +/-10'
Wheel Alignment
Front Axle:
Rear Axle:
