noisey fuel pump
noisey fuel pump
I was suffering a noisy whine and I think it may be the fuel pump its coming from the underside of the tank ,should you be able to hear any noise coming from the pump or should it be relativly silent ,I think this sounds like a miniture hairdryer.Its a 1990 c4 by the way.If I change the pump where's a good place to pick one up has anyone had this problem recently.Thank's guys.
I just changed mine today. I got a hell of a surprise when I wiggled the pump to see how to pull it out (after unbolting the mount), and it started dripping! The check valve had come loose of the pump...... the end nut was tight onto the bango fitting, but the check valve was not even hand tight...... My new pump is not silent, but very quiet. The old pump was sounding like a warning buzzer from below the fuse box.
I bought the pump for $223 delivered from one of the many web euro part places....... (not a renlist sponsor, but you should be able to figure it out)
noisey fuel pump
Jason,
The filter was easy to get to. I'm surprised how large it is. I can't see it ever being a problem without serious crap getting in the tank. I didn't take a good picture of the junk I found, but there were some fairly long pieces of debris along the bottom of the filter where the mesh attaches to the aluminum plug. I used a pick to remove the debris. It looked just like the metal spit out when you drill something. Metal spirals, mabe a half dozen pieces. I felt around the bottom of the tank, and it felt smooth...... But i'm still trying to figure out how the check valve loosened..... the new pump came with it securely attached.
