cam o-ring replacement
I have a 92C2 that has leaked, at what I assume is the cam o-ring as tighteneing the covers did not help, as long as I have owned it (4 years).
Has anyone replaced theirs? if so did you encounter any special problems.
I'm assuming that I will have to reset the cam timing, although the engine is just out and will have the pulley off this weekend. Speaking of the pulley, it appears that when the big aluminum bracket is off that one could remove some aluminum off the sides so that the hub would not have to be removed next time.
Abe
Abe
