Steering Wheel swap
I was wondering if anyone has performed a wheel swap and how do I remove my non-airbag steering wheel?
If you think that's a little basic, I am planning to change my gearbox oil this weekend, so I hope you're all suitably impressed!!!??
I'll remove the filler plug first... ...just in case!!
Cheers
Nick <img src="graemlins/wave.gif" border="0" alt="[byebye]" />
This is from memory, sometimes a dangerous thing
Pull the front horn pad off, including the wire attached to it. Mark the position of the big nut with paint or nail polish. This is a useful reference when you install the new wheel. Loosen the big nut with a 24mm-27mm (forget exact mm) socket, pulling the nut and washer off. Pull off the steering wheel. Here's where you're on your own. Don't know if you remove the slip ring and move it to the Momo adaptor. I do know when I installed my Momo wheel, I had to carefully sand down the plastic shroud around the steering column that the Momo adaptor goes into. If you have to do this, do it very carefully, as poor work will be very visable. I used sandpaper and, gently, a dremel. I know another person who used sandpaper attached to a small can to keep a curved surface for sanding. I also found it easier to remove the two plastic pieces, although it's a pain if you have the computer in the tach, which adds another lever you need to undo before you can remove the plastic shrouds. Assembly, as they say, is the reverse. Make sure you test the horn before putting it all back together. The hardest part will be torquing the nut back to 33 ft lbs. Do NOT use the steering locking mechanism as leverage to torque against. I put my key in the ignition and turned it slightly just to ensure the steering column was unlocked.
If you go over to the Rennlist email archives, there were some detailed procedures posted, I believe in the racing forum, on how to remove just one airbag. You will need to use a Porsche airbag test tool. The airbag connector plugs into the test tool, which tells the computer all is well. The passenger side remains armed and ready.
I replaced the steering wheel on my 1990C2 with a Momo. I'm not sure if the america versions are different, but mine took about 10mins from start to finish without the need for any sanding or 'dremelling'. It was a literally a straight swap as the Momo boss sits about 2mm away from the plastic shroud and looks like it came from the factory. Yours should be just the same.
It's one of the best upgrades IMHO, looks and feels great, especially if you get a Porsche centre crest instead of the Momo one.
Rob
The reason I ask is that I have been looking at other steering wheels (RS etc.) as I need a smaller diameter wheel. The reason is my thigh gets in the way when turning the wheel and working the clutch. I'd rather see if I can get a smaller wheel rather than working the gears without using the clutch , rally style......
thanks!
</strong>
The standard 4-spoke non-airbag wheel has a 38cm diameter.
I'm in the process of changing steering wheels myself, as I have a similar problem, but with my right leg (my car is LHD).
Instead of going for a smaller wheel (as I originally intended), I'm going for the 964RS wheel (also 38cm, but thicker rim, 3 spokes) in combination with a made-to-measure hub that places the new wheel 6cm further away from the dash.
Cheers,
JW
I will keep the retro-crappy 4 spoke in storage just in case.
Christer
Where did you buy your RS wheel from and how much (including the spacer)?
...and JW Hubbers , have you got any pictures of the 964RS steering wheel...I wasn't aware that it was a 3 spoker...I thought it was a standard 4 spoke steering wheel with an RS centre pad.
Cheers
Anil
<strong>Christer
Anil</strong><hr></blockquote>
I purchased mine at Porscheshop here in the UK. The price was around£275 incl VAT and delivery.
I can get you a picture of it after it arrives....
Christer
I replaced mine a couple of months ago from PorscheShop. I'd be interested to know how long yours takes to arrive - they told me it was in stock and would arrive in 2 days. I got it 2 weeks later because "they didn't have the correct centre in for 964", then "the wrong one was sent to us" etc. even though they told me twice they had sent it.
One thing you should check before you fit it:
You need to remove the back from your steering wheel (basically a plastic ring with a tab to cancel the indicators) and add this onto the new steering wheel. But - you can only fit it in one place (because it has to line up with a hole for the horn connector). When I did this, the tab for the indicator was near the bottom - and hence didn't cancel the indicators one way. I had to unscrew the steering wheel from the centre and there are a second set of holes which I needed to use to get the indicator tab level with the indicator switch.
Also - on mine, the electrical spade connector for the horn is a different size so you will need to sort this if yours is the same.
Dave
90 C4
thanks for the heads up though!
