964 Forum 1989-1994
Flywheel Failure - revisited
Old 06-25-2002, 07:34 AM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
Talking
Dear Rich,
There are quite a few possible scenarios on how the LUK ended up on your RSA. Most likely was that it was fitted after delivery to the USA. Now the first customer may have insisted before personally taking delivery. Your engine could have been allocated to another 964 on the 1992 production line, it failed a quality test, was stripped down, repaired, the LUK installed for whatever reason and then this engine was re-allocated to your RSA.
Finding out would be almost impossible. I doubt that the records of such warranty work could be found anymore.
It was almost certainly not originally installed in this engine at initial production. It is far too early. Unless it was a test engine. One never knows and I am afraid we will never find out,
Ciao,
Adrian
911C4
PS: At least you do not have a flywheel problem to worry about.
Old 06-25-2002, 09:12 PM
Rich W
Rich W's Avatar
Post
Adrian,
I will defer to your judgement, as your experience in this arena far exceeds my own.
This little mystery just makes the car that much more intriguing to me.
Old 09-30-2011, 11:42 AM
bmohr
bmohr's Avatar
I have a 1990 c2, 1992 engine and 993 (96) tranny. Is there anyway, beyond removing the tranny that I could tell(visually) what flywheel I have? I'm trying to put one less fear out of my mind
Old 09-30-2011, 02:48 PM
Earlydays
Earlydays's Avatar
Starting with the 1992 model year the C2 had the updated LUK flywheel.
Old 09-30-2011, 02:59 PM
FeralComprehension
FeralComprehension's Avatar
You'll have to search for confirmation, but I believe I've read that a) you can see the flywheel edge via a cutout in the bellhousing (my C4 does have this cutout; look below the clutch slave), and b) the earlier less-desirable flywheels have a welded-on ring gear (visible weld beads) where the newer ones have a pressed-on ring gear with no visible weld beads.
Old 09-30-2011, 09:43 PM
bmohr
bmohr's Avatar
i suspected this "window" to the flywheel. My 99 C4 had two so I figured this would be the case, but wanted some advice before I jacked her up this weekend. Thanks for the heads up and details FeralComprension.
Quick Reply: Flywheel Failure - revisited
