Hi All
Over the past 2 years I've owned my C2 the cruise control stopped working a number of times. The problem fixes itself and the only correlation I can make is that it fails only on very hot days when the cabin temperature gets hot. It appears that an electronic device in the system is temperature sensitive?
Your thoughts are welcome
90C2
bj
90C2
bj
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear BJ,
First places to look is under the brake pedal and the clutch pedal (if a manual) to check the microswitches. The control unit maybe overheating but I would suspect the microswitches first. Give them a good clean up,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
Also, make sure your carpet isn't sliding too far forward. Many years ago, this kept my c.c. from engaging. I've since learned to keep the carpet secured and pulled back.
