964 Forum 1989-1994
Headlight Washers Mystery
Old Aug 26, 2002 | 02:37 PM
J-McDonald's Avatar
J-McDonald
Post Headlight Washers Mystery
My '91 C2 has what appear to be factory headlight washers in the top of the front bumper cover.
In response to the recent posts about headlight washers, when I tried to use my headlight washers by pushing the right stalk forward, I noticed that my stalk doesn't go forward. Comparing the picture of the right stalk in my owner's manual to the one in my car, I found that I don't have a stalk that provides for operation of the headlight washers (the stalk in the owner's manual has two little "pictures" on it, one of a windshield with the "M" shaped stream of water, and one of a headlight with the "M" shaped stream of water - the stalk in my car only has the former picture).
So, I'm guessing that either the previous owner replaced the front bumper cover with a bumper cover that had the headlight washers, or replaced the stalk with a non-headlight washer stalk.
Anyone have any ideas?
Old Aug 27, 2002 | 06:43 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Headlight washers were an option. All the scenarios you have mentioned could be correct of course. The only people who would really know are the POs. I would go for the replacement bumper as being most likely.
Ciao,
Adrian
911C4
Old Aug 27, 2002 | 08:09 AM
GaryN's Avatar
GaryN
Post
Hi John,
I would say more likely is that the stalk-colar on your car has been replaced. When I bought my car the intermittent wind-screen wiper was faulty. When I went down to my local OPC to buy a replacement stalk colar (which includes indicator stalk and computer stalk) they had plenty different combinations of stalks for a 964 and I remember that one of the option stalk colars were with-out headlight washers. <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
Cheers
Gary '91C2
Old Aug 28, 2002 | 08:20 PM
speedster 94's Avatar
speedster 94
Post
hallo
There is no stalk you can push forward. There are two options .
When your Headlights are on and you PULL on the right Stalk water sprays to your Windshield AND to your Headlights . Or
There is a little Switch on the Dashboard ,similar to the Clock set switch and in this area , you can push and the water will spray to your Headlight. On a 964 it should be the first option .You can also take off the cover under the AC Cooler on the Bumper and check if the watertank has Two Pumps installed instaed of
one . Than you have Headlightwashers .
Harald
Old Aug 29, 2002 | 07:12 AM
Taj's Avatar
Taj
Post
Harald,
Your description is not like my 91 C2. I have a stalk on the right that operates the wipers, and this has to be pushed towards the dash, with the headlights on for the washers to work. My washer bottle is inside the front wing and it has two pumps. The switch on the dash, is the intensive washer switch, and it sprays the contents of the intensive washer bottle onto the screen, not the headlamps. Maybe the speedster is different to a regular 964. I know that the RS's are different.
Taj.
Old Aug 29, 2002 | 05:47 PM
speedster 94
Post
hallo
Sorry i got mixed up with my workhorse (BMW) and
the stalk has to be pushed towards the Dash . But it will only work with the Lights on .By the way i have the right stalk if you need it let me know.
Harald
Old Oct 6, 2009 | 09:38 AM
eldoguy66's Avatar
eldoguy66
I wonder if we have different washer options for us vs. euro spec cars.
