Rubberized Undercoat Source
Hi All
Does anyone have a source for the rubberized undercoating used on the under body or a comparable product? I have some exposed metal where this coating has been scrapped off and I'd like to repair it.
Your responses are appreciated
Bill
90C2
Bill
90C2
3M auto body seam sealer is pretty close to the factory coating. Be sure to spray some cold galvanizing or rust inhibiting paint on any bare metal first. Creeping rust can form behind the coating if you do not put rust inhibitors on the metal.
Thanks Andy and Springer
The waxoyl appears to be the same type of coating that has mostly worn off the engine block and other aluminum parts like the rear control arms.
Bill
90C2
Bill
90C2
the factory uses Wurth and has for eons - they have every thing you need
http://www.wurthusa.com/en/service/home.php
