Bleeding brakes on 964 C4...
It shouldn't take your wrench more than an hour to bleed the brakes, clutch cylinder, and even the accumulator and solenoid block, and since you've already bought the fluid, I think your best bet is to let your mechanic do the job. That way you know all your ducks are in a row for your first track day. Go out, enjoy the car, then go pick up a power bleeder and Adrian's book and when you've got more time, bleed them yourself. It's too important to mess around with when you're under a deadline, but it's very satisfying when you learn to do it yourself!
Brian
Brian
