Parts needed for valve adjustment
I'm about to do my first valve adjustment on my RSA. Does anyone on the forum have a recommended list of parts to replace. I've already ordered the valve cover gaskets, distributor caps, rotors, plugs, and filters. Are there any exhaust bolts or gaskets that need to be replaced during this procedure?
Check with your supplier of the valve cover gaskets. The valve cover gasket kits usually come with the gasket for the catalytic converter, and the bolts/nuts. (I'm assuming you already have the oil filter, and drain plug rings)
Technical Specialist
Lifetime Member
Lifetime Member
I got a valve cover gasket kit, with gaskets, including cat, as Eric mentioned, and nuts and bolts for $46 from Porsche last September. PN 964.105.902.00
Technical Guru
900-074-339-02 (2) Exhaust Bolt Hex-hd M8 x70
999-025-125-09 (4) Washer 8.4 x 17 x 3.1
999-084-052-02 (2) locking nut M8
Sorry I don't have the part number for the catalytic converter gasket, mine came with the Porsche dealer kit.
Thanks for all the advice. I ordered the parts from Sunset Porsche over the phone and just ordered the gaskets, not a kit. I'll call them back and see if I can switch for the kit or order the exhaust parts separately.
