964 Forum 1989-1994
Door switch removal
Old May 4, 2003 | 06:07 PM
MDH's Avatar
MDH
Post Door switch removal
Any trick to getting the door button switch out? I tool off the rubber cover and find a botton switch held against a little bowl-shaped piece of metal. I tried to pry the funnel shaped piece out but it won't budge. I need to replace the switch.
Old May 4, 2003 | 08:08 PM
Roly Baldwin's Avatar
Roly Baldwin
Post
A while back I fixed the switch and replaced the rubbers. I'm pretty sure it just unscrews.
Old May 4, 2003 | 10:07 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Post
All you need is a wrench with a 11mm socket.
Old May 5, 2003 | 01:46 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
That's it! ...once you remove the switch, keep track of the fiber washer, etc.
You will basically have to cut the wire off the switch, re-strip it @1/4" or so and crimp it into the new switch.
During reassembly, make sure you get the fiber washer in there so the switch it closer to your door...or you will have issues with the interior light staying on, alarm function, etc.
Old May 5, 2003 | 05:55 AM
Madridcab's Avatar
Madridcab
Post
Just had this issue, caused by lack of proper grounding, unscrewing the switch, cleaning contact points (hole in doorframe and hinges)with metal-clean and screwing back in, and my interior lights now come on and off as they should... and in my case no need to replace switch. Does anyone know if the rubber protection is available on it´s own??
Old May 5, 2003 | 06:24 AM
Roly Baldwin
Post
Yes - Porsche sell them for pennies. Well, GBP1.94 actually. Not only do they keep out dirt and water, but shiny new ones look nice too <img border="0" title="" alt="[Wink]" src="wink.gif" />
The engine cover switch also has this rubber so it might be worth replacing at the same time as the door switches...
Nearly forgot - the part number is 901.615.616.20.
Old Jun 24, 2003 | 03:08 PM
Dave R.'s Avatar
Dave R.
Post
OK, 11mm socket. However, my door contact switches just seem to rotate without unscrewing.
Does one also have to hold the switch barrel from behind? If so, what access, through the upholstery?
-Dave
Old Jun 24, 2003 | 04:30 PM
colorwood's Avatar
colorwood
Post
I did mine a while back in the way described above...as far as I can tell there is no access from behind and the advice I read at the time was very specific about the dangers of overtightening/stripping threads etc on replacement. Hope this hasn't happened to yours!
