964 Forum 1989-1994
Gear selector joint, ever replaced?
Old May 30, 2002 | 02:52 PM
Arjan B.'s Avatar
Arjan B.
Cool Gear selector joint, ever replaced?
Hi,
Has anybody ever replaced the ajustable joint which is on the front end of the gear selector pipe in the tunnel under a 964.
It's a sort of ball joint construction but mine has some play there.
Is this o.k. or do I have to replace it??
So yes, is it easy to do? [looks easy to do for me]
Please response.
Thanks,
Arjan
964 C2 1992 Black <img src="confused.gif" border="0">
Old May 31, 2002 | 04:49 PM
Targamike's Avatar
Targamike
Post
I'm not sure about the joint to which you are referring.
I just replaced my shift rod/shift coupling. This aluminum coupling which connects the rod coming from the shifter to the rod coming out of the transmission had cracked on my car. Replpacement was quite simple. If this is the part that you are referring to, just make sure that you use Loctite thread lock on the shoulder bolt that holds the coupler to the transmision rod.
Old Jun 2, 2002 | 07:14 AM
Arjan B.'s Avatar
Arjan B.
Cool
Hi,
No, I ment the one exactly on the other side, the one ont the cars 's front, on the front tunnel end.
Just behind the steering rack area.
Thanks for response.
Arjan
964 C2 1992 Black
