Non aircon temp sensor
Am i right in thinking there is a temp sensor behind the dash to sort of control the heaters.
Does anyone know where it is and how to check/replace it.
Also, the leds that light up behind the centre console switches (spoiler lift, hazard lights etc), can anyone tell me the power draw or current of them as I need to replace a couple.
Thanks in advance.
Check your servos are working - failure of the heat control servos is a common fault.
This link should tell you what you need to know
<a href="http://www.nethereal.co.uk/964/heater_servos/" target="_blank">http://www.nethereal.co.uk/964/heater_servos/</a>
