Thanks to Rennlist - again!
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Just a quick post to say that Rennlist has got to be one of the best marque boards going.
I was having a few of the usual problems with cabin heating (or not!). Searched the posts, found Roly Baldwin's excellent article about his own problems on John's website and got stuck in.
I would never have tried such a repair without the advice in his article and here on the board. The heating works perfectly now and I have a certain sense of achievement from having repaired the 2 servos and saved myself a few quid into the bargain!
Cheers,
Adrian.
Cheers,
Adrian.
I lost heat on the pax side first, then drivers a bit later.
Have you had heat and it's recently stopped or have you never had heat?
Not sure where you'd start if you've never had warm air, but if, like me, it's recently stopped then you need to check out what's actually happening with your servos. Use Roly Baldwin's article on John Miles site here .
Once you get started it's actually quite straighforward.
Good luck.
Good luck.
